Old-Biscuit
Jan 12, 2015Explorer III
Snip-the-tip is easiest, works well AND gives you a mini adjustment controller.
Otherwise you have to try and pull new thermistor wiring thru fridge liner and insulation down to control module without damaging the wire.
Control module is accessed via outside lower vent........thermistor plugs into P2 connection on board.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
