LaunchnRetrieve
Jan 12, 2015Explorer
Old-Biscuit wrote:
Snip-the-tip is easiest, works well AND gives you a mini adjustment controller.
Otherwise you have to try and pull new thermistor wiring thru fridge liner and insulation down to control module without damaging the wire.
Control module is accessed via outside lower vent........thermistor plugs into P2 connection on board.
Thanks Old Biscuit. I thought the board might be accessed from the outside.
I guess the first thing I should do is check the board end to make sure it's even plugged in.
Do local mom/pop RV stores have the snip product or is that just an online purchase? I'll find out soon enough once the stores are open again.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
