LaunchnRetrieve
Jan 13, 2015Explorer
dougrainer wrote:
Are you POSITIVE the thermistor inside the refer is attached to the fins and not hanging loose? If it hangs loose the refer will freeze. Doug
Clip IS attached to fin at right side of fridge.
Will look to see where tip of thermistor is relative to clip.
Will attempt resistance ice batch test this weekend (too dark to check after work, parked on street, don't want to get run over searching for controller board).
Does sliding the clip up or down on the fin affect the temperature at all?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
