dougrainer
Jan 14, 2015Nomad
BAD Thermisters can OHM correctly. The Thermister is NOT sensing the air temp but the evap fin temp. The air temp will be 10 degrees warmer than the fin temp. If your refer is at 36 degrees the fin temp will be 26 degrees and that 26 is what the Thermister is responding too. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
