Sandia_Man
Jan 15, 2015Explorer II
Another vote for the snip the tip modification. Takes just a few minutes and gives the ability to adjust temp on Dometics that do not have that capability. I've also omhed out the thermistor and it appeared within specs, but once I performed the snip the tip mod (which uses the same exact set of wires to the control board) the problem was solved. I believe that this mod is only available online.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
