Temperature swing was too high in cold weather. Stat allows changing differential from 2 to 1 degree. Problem with "1d" is that the heat relay in Dometic controller chatters on and off very quickly. S...
Verify settings on thermostat to insure it is set up for your system. Heat pump or furnace? Exact model of thermostat? See page three System initialization Manual
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
