dougrainer
Sep 29, 2018Nomad
Hobo2 wrote:
I took off cover and steel plate, didn't see any corrosion. Jiggled al wires they were tight. Unhooked connection on ack of thermostat. Everything was running fine all summer,first cool night I turned power off. Went to turn on and E1 comes up. Any ideals or know of a good rv man on eastern shore Maryland
You did not do everything I told you. You checked the modular connects at the BOARD. The connections at the board, those are short 12 inch pigtails that go into the evap area and connect to the wires from the tstat and other AC control board. You have to remove that large plastic evap cover to see and check those connections. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
