jmiller12 wrote:
dougrainer, The inside trailer and outside temp was way less than 110 deg, probably around 75 in San Diego. Also, the unit is a 2018 Winnebago Minnie model, so the tstat is a new. I am glad to hear that you don't have any problems, but other people have posted reviews that have the same problem as me. To be specific, I can press the power button ONE time, and the tstat will cycle from fan to cool to furnace and then off. When I finally do get the unit to stay on cool, if I try to adjust the temperature up or down, one press of the arrow cycles the unit from cool, to furnace then off. Sometimes it switches from F to C hitting one button rather than press both arrows simultaneously. Is it possible that the control board is causing the issue rather than the tstat?
I made a mistake. The CT is the NEWEST version of the old single zone Tstat. The CT did not have any problems. The most common problem is user related. PUSHING the areas for the buttons instead of lightly touching. The Tstat responds like your screen on a smart phone. But, the problem if it is a problem will be the wall tstat. Doug
PS. the CT stands for----
Capacitive Touch (CT)
