NinerBikes
Oct 04, 2015Explorer
check your cooktop stove and see if it still ignites and has propane. It may be something as simple as out of propane, the tank ran empty, and you need to switch the propane tank to the other full tank, and refill the empty tank.
If the propane tank is empty and you switch tanks, turn your refrigerator off, then back on, to reset and retry starting the fridge again.
