Chris_Bryant
Oct 04, 2015Explorer II
First- turn it off and back on. That should reset the check light. It should not come back on right away, if at all. If it does come back on, it means the refrigerator is not seeing the 120 volt power, and it's trying to ignite on LP.
It is plugged in inside the cover on the outside of the RV- there is a standard outlet and cord for the 120 volt power. This outlet is also controlled by the ground fault interrupter outlet- usually they are in the bathroom- they are the outlets with the buttons in the center. Most common is for these to trip. Check them first.
