j-d
Oct 04, 2015Explorer II
Yes! Needs 12-Volts-DC (Battery or Converter from 120-Volts-AC) to run the Fridge's Logic Board. The one with the fuses Chris Bryant mentioned. There is probably also a fuse on your Power Center designated Fridge. That would be only for that Board. The "Fuel" is either LPG from your tank or 120-Volts-AC, again through your Power Center (but on a Circuit Breaker this time, probably with other items) and the circuit will probably be either ON a GFCI outlet or downstream of another GFCI in your coach, likely the Bathroom.
So, you gotta have 12VDC Control Voltage AND LPG or 12VDC Control Voltage AND 120VAC. LPG or 120VAC alone will not run the Fridge.
