etki84's avatar
etki84
Dometic Dm2852 eyebrow board bypass info needed
Can anyone tell me how to bypass the 6 pin connector on the eyebrow board on a Dometic Dm2852 to make it run on ac power. I am helping a buddy that just bought an rv and he was told that it will only run on lpg. He took the board off when trying to trouble shoot it and the board got thrown away. I want to test the unit before spending money on a new board. I tested the wires and we have power going to the board. I don't think the 12 volt is hooked up to the fridge as well.
  • enblethen wrote:
    OP you said you have power to board but also said it got thrown away. Which is it?
    You could apply power directly to the 120-volt element. It should start cooling the refer if it is good.
    Good chance that the 120-volt relay on board has or had failed.
    I tested the plug that plugs into the eyebrow board, that is how i know there is power coming from the bottom board to the top, the bottom board is new. from what i can tell the top board is a simple two button board with just two led lights. There should be a way to jump the top plug to make the unit come on.
  • Disconnect and the 120v cord from the board
    Disconnect the 120v heating element leads from the board, connect heater leads to cord, plug cord into the fridge compartment outlet ,
    It is now direct wired and will cool to maximize capability, will never cycle off as long as trailer has 120v
  • OP you said you have power to board but also said it got thrown away. Which is it?
  • The board "runs" on 12VDC, whether on propane or 120 VAC.
    No 12VDC and it will NOT work on either heat source.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
