Iceman31
Apr 30, 2015Explorer
Dometic DM2852 Fridge Issues - Need some advice
I am having issues with my unit. I turned it on last night for my weekend out at the lake coming up. Went back out to the lake tonight to find the fridge and freezer very warm. Last year I replaced the thermistor with one of those snip the tip units and it seemed to work for awhile. I had unplugged the thermistor and it seemed to work OK for the remainder of last season. The thermistor was plugged in again when I turned it on last night. I have a new direct replacement thermistor which I could install but am not sure that is the problem. I am contemplating switching it to propane to see what kind of temps I will see. Could my electrical board be on it's way out? Looking for some advice as to what to look for here. When the fridge was quite warm you could hear a gurgling noise like the fluid inside the pipes was bubbling hot. Any advice? Is it worth changing my thermistor? Should I try it on propane? Should I just call a repairman?
