dougrainer
Feb 08, 2022Nomad
jeffn74 wrote:
I got a little anxious and decided to check the temperature inside the fridge after a few hours. The freezer is at 22F and the outside temp is 62F. The heater element and cooling system appear to be working fine. I will let this run for the prescribed 24hrs.
I ordered a lower board today and it should arrive tomorrow. Any other ideas? Thanks!
Freezer temp is 0 to 10 degrees. Refer temp will be 26 to 38 degrees. I would suspect the eyebrow more than the rear control board, because you state the Gas button is finicky. What year is your refer. Doug
