jeffn74's avatar
jeffn74
Dometic DM2852 Not working on AC
Hi,
My Dometic DM2852 fridge is not working on 120VAC. I have an LP leak so I have not confirmed that the fridge is working on LP. I am waiting for my new regulator and pigtails to arrive.
Anyway, I have checked the following
1. 12V is OK the lower board. Fuse is good.
2. 120VAC is OK the lower board. Fuse is good.
3. Heater element is 42ohms. Appears in spec.
4. NO 120VAC at the heater element measured on the board.
4. The eyebrow board has a finicky GAS button. It sticks a little.
5. Measurements of the P1 connector when attached to the lower board show...
RED is ground
Orange is 12V
Black is 12V
Green is 12V
Does it make sense for the black and the green to both be at 12V? I expected the black to be 12V when selecting 120VAC and the green to be 12V when selecting LP.
Is there a way to bypass the eyebrow board to force 120VAC operation? For example, tie P1-3 (black) directly to 12V and check to see if the 120VAC appears at the heater element (the eyebrow board will be disconnected from the lower board while performing this test).
I am suspecting a bad lower board, but I want to confirm this before buying a new one.
Any help is appreciated. Thanks!
-Jeff
  • The wires from the lower rear board to the eyebrow are buried inside the BOX and insulation of the Refer. SO, no access to check the wiring. There are no good ways to "test" an Eyebrow other than replacing with a new one and see if that fixes the problem. I have had just 1 Dometic in 30 years that had an internal eyebrow problem and that was under warranty. Unless you have had rodents chew up the box insulation and your box is in good shape, then the wiring will be OK. BTW, There is NO WAY your interior temp was 14 degrees. NO WAY. What type of Thermometer were you using? The CORRECT way to determine interion refer temp(not the freezer) Is leaving a small glass of water inside after the 24 hour test and measuring the water temp. RV refers, the FINS will be 10 degrees colder than the interior temp. So, for you to have 14 degrees would mean the fins were 4 degrees, 2 degrees warmer than the freezer temp. In 42 years as a RV tech I have NEVER seen a RV refer get colder than about 24 to 26 degrees. Doug
  • I figured out what the root cause of the problem. It was a finicky switch on the eyebrow board. I was barely able to remove the eyebrow board from the fridge with the slide outs in. I was standing on a chair leaning towards the fridge and stretching out as far as I could reach. Not the easiest thing to do! I then proceeded to my analysis. Here is what I did:
    1. Visual inspection of the board to look for broken traces and signs of EOS (electrical over stress). No problems found.
    2. Resistance measurement of all the resistors. No opens found.
    3. Diode checking of the zener diode on the board. No problem found.
    4. Resistance measurement of both switches. A problem was found.
    The Auto/GAS switch exhibited erratic resistance measurements when depressed. It was NOT a short as expected, but a much higher resistance and a borderline open. I then proceeded to take the switch apart. This can be done without desoldering the switch from the board. I should have taken pictures, but I was in a hurry to put this project to bed. I opened up the switch carefully since there is a spring and small contacts on the plunger portion. I performed a visual inspection under my lower power optical mircroscope and found signs of corrosion and tranished metal on the contacts. I gently scraped the tarnished contacts with tweezers and cleaned them with rubbing alcohol. The contacts inside the switch housing were cleaned with compressed electrical contact cleaner since I could not get a cotton swab inside. I then reassembled the switch and verifed that the resistance measurements where now correct. The switch was now acting as a short when the button was depressed.
    I then proceeded to reassemble and install the eyebrow board in the RV. After turning the unit ON, I measured the voltage going to the heater and confirmed 120VAC. This showed me that everything was working well. Also the gas relays on the lower control board where no longer switching since the board determined that 120VAC was present.
    I let the fridge run over night and the temperatures are as expected. Problem solved! Going forward, I am going to find a source for the switches. My experience shows that cleaned, but once corroded switch contacts might last a long time or they might eventually become a problem again.
    In regards to the temps. The measurements were made over 24hrs with the heater on 100% of the time. This will give a much lower temperature than having a refrigerator cycling off and on according to the thermistor based control loop. I also used an infrared thermometer and shined it into the fridge. As I stated, I cannot totally access the fridge due to my slide outs being closed. I can only open the doors by a 1/2". There is no way to put a glass of water in there and measure it thermally. At the end of the day the temperature measurements are what we in the engineering world call "good enough". It shows me that the failure is not in the cooling unit, but somewhere else.
  • You CANNOT use a IR thermometer to get temps in an RV refer. Same with roof AC temp. PERIOD. When I test RV refers, I utilize the 24 hour 120 method and use a cup of water for the CORRECT temp. Doug
  • Well I did use an IR thermometer! There is no need to get mad and yell at me.
    My fridge is working now. I figured that a well documented attempt at troubleshooting along with a solution would be a valuable asset to this forum. I was going to make another post once I found a supplier for the switches, but I am done. I have better things to do that get yelled at.
    I am not yelling at you. I am stating facts and to make sure you understand why. Your documentation was excellent. I wish more posters would give detailed info like you did. I am a Master Certified RV Technician with 43 years. Doug
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
