I am running out of options trying to fix our Dometic 2852 fridge. The problem is that it tries to run on propane when it is plugged in. First I checked power all the way to the board, meter is ...
Have you checked AC voltage at the pins on the board? Its altogether possible you have a bad connector either at the AC input or output connections. BTW Dinosaur boards are much bettet than OE stuff at lower cost. If your still stuck on Monday give them a call. They have proven to be helpful to others.
