I am running out of options trying to fix our Dometic 2852 fridge. The problem is that it tries to run on propane when it is plugged in. First I checked power all the way to the board, meter is ...
I will certainly try that. I think you are suggesting bypassing the setting on the upper board that selects AUTO/GAS and jumping to just AUTO manually?
It will be tomorrow morning before I can test when I get home. I will note that it does switch on the AUTO LED light when the switch is in AUTO currently, but the indicator could be dumb to what is actually being signaled. I will report once I try.
Thanks!
