JPG77373ExplorerApr 28, 2018Dometic DM2852I am running out of options trying to fix our Dometic 2852 fridge. The problem is that it tries to run on propane when it is plugged in. First I checked power all the way to the board, meter is ...Show More
wrgrs50sExplorerApr 28, 2018I had the exact same issue and replaced the lower circuit board with a Dinosaur board and still same problem with only working on propane. I purchased a new eyebrow board on amazon and problem solved. Works perfect now.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentDometic fridge DM2852 No powerDometic DM2852 Not working on ACDometic Dm2852 eyebrow board bypass info neededDometic dm2852 helpService Manual Needed - Dometic DM2852
