Having the same issues, blink light on temp side,, and noticed the fan will run at times and not run at times. suspect it's either going bad or getting weak or something from the control module that there is 3 wires to it and have read it power, neg and feedback..
couple time when restarting noticed when compressor started the fan would "jump" and then not spin.. could take screwdrvier and spin blade to get started.. other times it starts and sping on it own.
did notice the other night the speed would go up and then down.. its rated at 2400 RPM so at full speed it moves a lot of air.. it ramps for 5 or so seconds then dies back to slower.. not sure what normal speed is as i have not sat and watched it like now..
Suspect when the fan is not running and compressor is it causes the compressor to get flooded
with refrigerant
and high head forcing a shut off and the blinking light is error light. ? trying to find the fan motor.. drf 292wepoo 04 02b with NO luck.. the shaft is 2.25 long.. on amazon they are 1.5 to 1.25
