Berkyeng's avatar
Berkyeng
Dometic Duo Therm AC issue
Hi All
For background I have a 2009 Berkshire 390BH DP Class A. It has dual Duo Therm ACs.
I’ve been having a problem at temps over about 30C. When it gets hot outside, my front AC will shut down. The 5 button DuoTherm Comfort Control thermostat will go “blank” for Zone 1 (still shows the zone numbers on the bottom). The rear AC continues to function and Zone 2 is still accessible. Once this week, with the extreme heat, both ACs went out with both Zone 1 and 2 going blank. Once the outside temp goes down and the direct sun is off the units (night time) things go back functioning well and the 2 ACs nicely cool my motor home.
My RV dealer suspects a communication issue, but I beg to differ and believe this to be heat related (outside temp). Thoughts? Is there a thermal relay on the motor that shuts the system down?
I have blown out / cleaned out the outside fins and the components seem relatively clean considering the motor home is 12 years old.
Thoughts on additional troubleshooting I can do on my own? Otherwise will be making a trip to the dealer for service.
Thanks!
  • One way you can find out is replace the controller. I ripped out the digital thermostat and "smart" controller from mine and put in a "dumb" relay box that I then hooked up to a Honeywell T6 Pro ZWave thermostat (works without a C-Wire and while not rated for 12V works just fine). With the dumb box in place you could literally use a paperclip to jump the 12V + to the fan low on the AC and make it work (until it iced up).
Having RV issues? Connect with others who have been in your shoes.24,296 PostsLatest Activity: Aug 05, 2025
