Chris_Bryant
Jun 26, 2016Explorer II
You got the correct readings- Do NOT jump the yellow to red or you might burn up the thermostat. DuoTherm switches the grounds on that system, not hots.
Just ground out the yellow up at the roof unit- that will bypass the thermostat and wiring. If it still doesn't come on, it could be a bad freeze sensor. That you can usually short out to test.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
