Woodtroll
Jun 27, 2016Explorer
Well, using the manual, the wiring diagrams, and a lot of patience, I figured out that the problem is the relay (in the circuit board on the AC unit itself) that turns the signal from the yellow thermostat wire into a coil control for 120VAC to pass through the NO relay to the compressor. The relay is mounted to a circuit board labeled Etratech 50-001401-A. I cannot find this board available anywhere for sale (the camper is now 13 years old, after all), but the relay itself is still available in identical form for $12 or so shipped. I ordered one thinking I might be able to solder the new one in if I can't find the board. I have good wire soldering skills, but have never tried to work on a circuit board before. Luckily, it looks like this relay has sizeable lugs that are not cramped up against other solder points. If I can get the old one loose, I should be able to get the new one in.
Anyone know a source for the whole board, or an updated part number, just in case my replacement work does not turn out well?
Thanks very much!
Regan
Thanks very much!
Regan
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
