dougrainer
Jun 20, 2016Nomad
If you have a 100 psi compressor, just use compressed air with the blow out nozzle. In 37 years, I have never had to pull a refer to pull the baffle to clean it. I use a special built air nozzle that blows up from the burner. THAT will clean out the baffle and flue. FYI, you have not checked the LP pressure. THAT is usually the cause of low performance on LP after checking the burner and the orifice. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
