newman_fulltime
Feb 16, 2016Explorer II
Old-Biscuit wrote:it sure/sounbds like a voltage/problem happening only at night lights on more draw on the batt regaurdless plugged in or not
DC Voltage is critical for proper operation
Are you plugged into AC Power source or running off battery?
On propane.......spark electrode has to have correct gap (1/8") and must be engulfed in flame when lit and needs to be centered directly over burner slots (which need to be clear/unobstructed)
When it doesn't relight turn on ALL Stove top burners..check how the flames are (Steady/strong/blue tinges-------or fluctuating/different sizes etc.)
LP Regulator not supplying proper propane pressure.
Manual
