sgfrye wrote:
Ok am I missing something. My dometic DM2852 was running fine on this past weekends trip. Get home no power on 120 or dc. No lights on display, interior light nothing. What I’ve done so far:
Used multi tester on dc terminal block shows 13.7 volts. House battery is 1 12volt tests fine.
110 v outlet fridge plugged into cks out ok
Checked 3amp and 5amp fuse on control board checks ok with a “green light led” fuse checker.
Am I missing something or is next step replacing control board?
As always thanks!
There is NO on/off switch on your circuit board so don't bother looking for that
You have 13.7V DC at terminal block.....but no upper display OR interior light.
5A fuse is for the 120V AC circuit
3A fuse is the DC fuse for circuit board and all controls
Testing them with a 'fuse tester' just means the fuse is intact....but doesn't check that DC Voltage is present
Upper display is via 6 pin connector (P1---upper left corner) and the interior light/heater strip come from J2 connections----two completely different DC circuits.
You need to TEST using a voltmeter that you have 12V DC Voltage at J4......that is where the DC from terminal block goes to on circuit board AFTER going thru the 2 thermal fuses
(1 in-line down by burner and the other 1 on stack/which is resettable if tripped----RED wires from terminal to thermal fuses to J4)
W/O DC at J4 NOTHING will function
If you have DC at J4 then circuit board is most likely bad cause of different components being w/o DC
If you do NOT have DC at J4 then stack thermal fuse has tripped and cooling unit has probably failed.
Voltmeter.......test for voltage!
