sgfrye wrote:
BFL13 wrote:
There is a "thermo" and also a "thermal" Not clear what's what.
http://www.dyersonline.com/dometic-refrigerator-thermo-fuse.html
http://www.dyersonline.com/dometic-refrigerator-thermal-fuse-assembly-7-9cf.html
My problem is the thermal fuse
The thermo disc pop out on mine did not trip.
Im buying a thermal fuse only not the 61 dollar part you linked. I will install fuse where i removed orginal fuse. Couple bucks for just the fuer
The WIRED Thermal fuse is a FLAME fuse. If the unit catches fire from a leaking Cooling Unit AT THE BURNER, the flames melt/burn that Thermal fuse and shuts power down to the refer. In the 15 or so years since Dometic started installing that wired Fuse, I have NEVER had one fail. Doug
