Old-Biscuit wrote:
dougrainer wrote:
sgfrye wrote:
BFL13 wrote:
There is a "thermo" and also a "thermal" Not clear what's what.
http://www.dyersonline.com/dometic-refrigerator-thermo-fuse.html
http://www.dyersonline.com/dometic-refrigerator-thermal-fuse-assembly-7-9cf.html
My problem is the thermal fuse
The thermo disc pop out on mine did not trip.
Im buying a thermal fuse only not the 61 dollar part you linked. I will install fuse where i removed orginal fuse. Couple bucks for just the fuer
The WIRED Thermal fuse is a FLAME fuse. If the unit catches fire from a leaking Cooling Unit AT THE BURNER, the flames melt/burn that Thermal fuse and shuts power down to the refer. In the 15 or so years since Dometic started installing that wired Fuse, I have NEVER had one fail. Doug
Their in lines the real issue.....
It only shuts down power to fridge AFTER A FIRE.
:S
NO, It kills power to the Fridge when the fuse melts. With NO source(LP flame) to keep the flame GOING, the flame snuffs out. You can have a BAD flame from a dirty burner and/or rodent/insect nests that would cause a flame flare out of the burner area and that fuse would shut down the refer also. Doug
