stan909's avatar
stan909
dometic fridge doesn't self ignite
Fridge works great on AC and gas but I now have to ignite it by hand. Ideas anyone?
  • That's interesting. I was on the Central California coast when this happened. Humidity was high. Very dry here in Inland Empire I will file that away for the future. Thanks. Thanks also to Admin for moving this to correct forum.
  • I had a leaky creamic body on the electrode, it was OK after it was running and got hot but if you let it set a few weeks it would absorb moisture and not spark. I replaced it and it was fine when I sold the TT.
  • stan909 wrote:
    I went and unplugged and replugged in all the connectors to the igniter board and it fired right up. Maybe the leads were a little corroded. It is 20 years old after all.
    Doesn't take much to stop 12V.
    Hope it continues to ignite.
  • I went and unplugged and replugged in all the connectors to the igniter board and it fired right up. Maybe the leads were a little corroded. It is 20 years old after all.
  • Does the electronic ignition make a spark?
    No spark....bad spark electrode, bad high tension wire, bad connection at board, bad ground connection.
