Travelin2
Jun 01, 2016Explorer
Chris Bryant wrote:
The three things that govern the size of the flame on that model are the LP pressure, the orifice, and the thermostat. The thermostat is basically an on/off affair, with the exception that off will be a small flame.
The only thing the thermostat reacts to is the interior temperature (and front panel setting), nothing else.
So you are saying that the flame will run at it's high setting until the fridge reaches it's set temp before it drops to it's "pilot" level? Or does the flame run on high until the boiler reaches a predetermined temp before dropping to pilot?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
