Old-Biscuit
Jun 01, 2016Explorer III
Gene&Ginny wrote:Travelin2 wrote:
.. Dometic RM2353 fridge.
... I installed a baffle to reduce the clearance between the cooling fins and the side wall from 3 1/2 inches down to 1/2 inch. ...
Could that be part of the problem? :h
3 1/2" is WAY out of tolerance for clearance
1/2" is a bit tight
Installation calls fo 1" minimum
Idea is for air flow up thru 'absorber' tubes (large slanted tubes just above bottom tank) and then across condenser fins and out upper vent
Manual
