Joe417
Jun 03, 2016Explorer
You don't see techs like that around here.
There isn't much to installing a new frig. I've pull my 6 cu.ft. unit twice, once by myself. Sat it on a rug and pulled it to the back door. It wasn't that heavy just a bit bulky to get hold of.
Before I found the problem with ours, I was contemplating replacing it with a larger unit.
You may be able to get a bit larger unit in the same space as you old unit, but the Pleasureways I've seen are pretty tight.
You may want to research adding a cooling fan when you install a replacement. I think they are worth the effort. I added a second fan with a switch to act as a backup and/or help with the cooling when it gets really hot out.
Good luck,
Good luck,
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
