dougrainer
May 10, 2021Nomad
The LP pressure should be 11.5 no load and with just the refer running 11.5. LP pressure is CRITICAL for correct Refer LP cooling. It is also BEST to check the LP pressure at the refer tap. Doug
LOTS OF SUGGESTIONS, BUT WITHOUT YEAR BRAND MODEL OF RV AND MODEL OF REFER AND IF IN A SLIDE OUT OR NOT, NOBODY CAN GIVE BETTER ANSWERS.
Last, WHY was the baffle replaced????????? How do we know the CORRECT length baffle was installed????? The baffle is CRITICAL for LP cooling
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
