NKnowland
May 17, 2021Explorer
NKnowland wrote:NRALIFR wrote:
I’d get a second opinion on that burner, or buy a manometer and check the LP pressure myself. It should be at least 11” wc WITH the LP system loaded about 50%, which means you ought to be running the furnace and water heater while checking the pressure.
I just noticed you said new baffle, so I removed that suggestion.
Seriously, check the LP pressure again. The flame can LOOK good, but still be too low btu-wise.
We’ve got a manometer and it reads 11.2 under load,
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
