dougrainer
Oct 29, 2015Nomad
The admin for this forum deleted the part of my thread that called your dealer/TECH a derogatory name. I stand by what I stated. DO NOT GO BACK TO THAT DEALER. They are not qualified to fix your problem. The problem you have is simple but the fix and who pays will be complicated. From your post, the OEM (NOT Dometic) did not install the refer and cabinet to specs(insulation not secured). So, Dometic will probably pay for a new cooling unit, but the modifications to the cabinet and insulation and adding a 12 volt fan will go back to the OEM maker of your Camper. Dometic is not responsible for anything other than the actual refer. You need to contac the OEM maker of your camper and ask if they will pay for another shop to fix your refer correctly. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
