COboondocker's avatar
COboondocker
Dometic fridge pilot blowing out while driving
We have the a new dometic 8 cu ft fridge in our eagle cap 960. the pilot light keeps blowing out while we're driving, every time. it has never once stayed on. i talked with our dealer and they said it might be an issue with the cover that dometic is replacing but we can't get in for a few days and i wanted a quicker fix because we're heading out of town. any recommendations?
  • No pilot..main flame is what gets lit by the spark electrode (click,click,click)
    Air flow is being disrupted down along side of rig...not uncommon with design of TCs (truck cab/camper configuration)
    Dometic does make an 'air foil kit'............Dometic 3108038.005
    You could block off 5-6 inches of openings on the inside of lower vent......leading edge.
    Example of a homemade 'air foil' guy did on his Bigfoot camper
  • adambeck7 wrote:
    s. i assumed that was a pilot lighting.
    No, that the Direct Spark ignition trying to start the gas burner.
    For now you may just have to shut if off when on the road.
  • sorry i just assumed that's what's happening. switch fridge to propane, goes click, click, click, then it works. i assumed that was a pilot lighting. anyway, we drive for a few hours and it's flashing that it's not working. i reset it, click, click, click and it's working again. repeat....
