sdtravis's avatar
sdtravis
Dometic Fridge Problem in a brand new unit
We have a 2021 Dynamax Isata 3 with a Dometic DMR-702 refrigerator that is acting up and could use some help from all of you experts on this topic. I have a request in to a warranty dealer to help with this, but did my own investigative work on this ahead of time in case they can't figure it out. (and dealer service is booked out months, so hoping to find a cure on my own and avoid the delay).
Here's the scenario: When refrigerator is on propane, the panel will eventually light up an error code and shut the refrigerator off. The error code is always the same -- two blinking lights, 1) LP AND 2) Temperature setting (important detail -- the error blinks whatever the setting is currently set to, not a specific LED). The troubleshooting manual calls out a series of error codes, but given that the LP light flashes AND the temperature led flashes, I'm thinking this is the warning condition where LP is not lighting.
This condition is not easily repeatable, and it oddly happens in the middle of the night, also when unplugged from shore power. When turning fridge off and on repeatedly it will relight flawlessly.
Fridge works on AC, no issue.
Batteries are 99% SoC throughout the night, BMV shows no voltage drop or issues.
Propane tank is full. Other gas appliances work perfectly.
Original thermal cutoff fuse has continuity.
Original thermistor tests resistance in spec.
As a last resort, I replaced the control board with a brand new board, no change, but at least now I have a backup board!
I ran one test to turn off the propane at the tank while the fridge was on -- this produced the same error condition on the display panel, leading me to believe this might be something related to propane flow or something along those lines.
What else should I test or consider? Bad propane regulator somehow killing the propane under cold conditions? Misadjusted regulator? Bad eyebrow board?
Specs:
Model: DMR702
Product: 936002904
SKU: 9600010870
  • Sounds like yOu have moisture in the propane line and at night its freezing up causing a no light issue.You need to purge your lines and get the moisture out of them
  • Difficult to imagine a brand-new unit failing like this, but I think you're on the right track with the propane supply.
    Propane regulators do fail. Replace it.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
