Old-Biscuit wrote:
The spark electrode is not getting power or is not sparking
NO power.....could be bad circuit on lower board/bad contact on lower board.
Pull connectors for 12V DC on board, clean contacts and make sure the pins are making good contact. Pull high voltage wire to ignitor and clean/check for tight connection.
Not sparking......could be cracked ceramic/could be bad high voltage wire/could be gap is not correct (3/16" and directly over burner slots)/could be bad electrode.
With it 'working by manually lighting'......then is sounds like problem with power to spark electrode
Which model of Dometic?
I'll get you the model number ASAP. Out of curiosity, is the lower board located behind the cover I pulled where all of the workings of the refrigerator are located?
