rvman69's avatar
rvman69
Dometic fridge RM2652 tripping thermal sensor
Hello all, my Dometic RM2652 in my 99 Travelmaster class C RV was in my level shop hooked up and running good. I went out one day after we had a pretty bad storm and our electricity went off and back on about 5 times in a short period of time. Then it stayed off for about 36 hours. I noticed that our fridge power light was not on the fridge. So I turned the fridge off and reset the thermal switch on the heat unit. I went back in and turned fridge on. The power came on and the auto light was on. So I thought well the storm just threw the thermal sensor. So I turned the fridge off so I could clean it thinking it was fine. Well today I went out to turn the fridge on to get ready to go camping at the end of the month. When I turned it on the the lights came on the control panel as it should. It was on for a while then later I noticed the lights on the fridge were off. I went back to the thermal sensor and it was thrown again. I reset it again and it did the same thing. The heating element is getting hot. I do not think the cooling unit is bad but not positive. I do not see any yellow or green looking stuff around the heat unit. Is there anything else I should check that could be making the fridge not operate correctly? Could it be that the thermal sensor switch is just bad? Would appreciate any help. Is there a way to post pictures on here? I was going to post a couple so you could see there seems to be no yellow or green looking stuff. Thanks
  • I tried posting a pic from the info I found on here. It will not let me post a pic. It keeps saying your post has invalid formatting.
  • No, the inner pipe would or may have carbon build up.
    It is the small by-metal thermostat similar to one I linked?
  • The thermal unit seems to be tight to the metal cover.The wires are tight on the unit.The stack seems to be clean. I would have to take it apart to look at burner pipe. Right? I am going to try to put a pic on here so you can see what you think. I did notice it seems like the top of the stack is not clipped in like the bottom is. It looks like it should be clipped in like the bottom. Should I take the stack apart some to see if there is any yellow junk in there? Thanks
  • Is the thermal unit tight to the metal cover?
    Are the wires tight onto the unit?
    Is the stack clean including the burner pipe located inside the stack?
    These button style thermal units are readily available for replacement.
    thermal fuse
