enblethen
Jun 05, 2017Nomad
Check the distance between the cooling unit and the exterior wall. This should be closed up to less then an inch.
Check the top of the refer above the cooling unit. Many have a void that needs to be closed up. I used a piece of metal duct. The curved portion forces the hot air out the top vent as the vent is located toward the outer wall.
I tried fans blowing through the cooling unit but did not achieve good results. Closing air space worked far better.
