dougrainer
Jun 05, 2017Nomad
You do NOT need air blowing up thru the Cooling unit coils. What you need is cooler fresh air THRU the upper Condenser FINS. As another poster stated, the GAP between the upper fins and the sidewall needs to be ZERO to 1 inch. You want to force all air THRU the condenser fins to remove the heat. So, just blowing UP from the bottom may not be the best way. I cannot see your pics. What the Refer makers do, is install the additional fans right below the upper condenser and that forces the air thru the fins and up and out the upper vent. Doug
