Mvpmich wrote:
I'd give my first born for a too cold fridge. It took two years, multiple adjustments/reinstallations, exhaust fans and a replacement just to get it to cool below 40. Slide the thermastor down an inch or two and use a recirculating fan ($12 at camping world or walmart) and you should be ok. Note the temps will rise up to five degrees each time you spend more than a few seconds in the fridge.
and put the beer on the top shelf!
OPs fridge doesn't have a 'thermistor'.........uses a capillary tube in a fixed position.
Moving a 'thermistor' will only affect temps in a fridge that uses a fixed factory preset thermostat.
If fridge has an adjustable temp control.......thermistor needs to be placed where recommended by mfg. (far right fin, 5th fin from right, 10th fin from right, etc. mid-position)
