enblethen
Nov 23, 2016Nomad
How did you test the 120 volt element?
Should check for continuity by disconnecting element from circuit board. If you do not disconnect from circuit board, you could be looking at resistance in circuit board and have a bad reading.
Check for 120 volt output from circuit board.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
