Mkos1980 wrote:
I have a 03 Springdale with a dometic fridge and seem to be having trouble with it. Out of storage I fired it up to test it out and all was ok. Went a week later to pre chill it for a trip and I came out the next morning to the "check light. I turned it off and back on and away I went again. Found it odd it would kick off esp with full propane tanks. This time I put it on auto. Came our 3 hours later and the check lights back on. It shouldn't be looking for gas esp since the trailers plugged in. Turn it back off and on and it resets itself. It seems every 3 hours it kicks off and doesn't know how to start itself back up
unless I turn it off and back on regardless if it's 120 or lp. Thoughts?
I don't know about your RV but on mine and many RV's without an inverter the fridge
needs DC power to run the thermostats. No or low DC and it can NOT turn back on. Makes no difference if you are plugged into ac shore power.
Mine would come on and like yours I'd find it shut off. That's because I had low DC power. And it will run till it hits temp and then when it shuts off it doesn't have the DC power to turn the thermostat to turn back on.
I also at the same time had my AC unit doing the same thing.
3 repair guys later and $$$. I was informed that both the AC and Fridge have to have DC power for their thermostats. :R
Check that your converter is putting out the correct amps or that it is even working.
My converter was working but putting out mega amps and boiling my battery then not working etc etc. One capacitor looked like it was shot with a 22.
