Old-Biscuit
Oct 06, 2020Explorer III
The Auto Temp Control DOES have a thermostat and thermistor....just doesn't have Temp Setting Adjustments
The Thermistor (Temp sensor) attached to FIN can be moved to adjust overall fridge temps
Move thermistor UP for colder
Move thermistor DOWN for less cold
In your 'friends' case....DOWN
In AUTO the fridge controls will select AC Power (Priority)
If AC Power becomes unavailable the fridge swaps to GAS
It will swap back to AC when AC Power is restored
If you select GAS Manually the fridge will only run on GAS ...no swapping back to AC Power
CHECK Light comes ON when GAS Fails to light off and prove a flame is present.
Several Dometic Models use the Auto Temp Control
This Manual covers some of them
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
