Sandia_Man
Oct 07, 2020Explorer II
My Dometic fridge is same as you described, no lights when on propane only. We spend most of our time RVing off of the power grid thus we just set fridge to propane, plus it tends to cool better in that mode. Fin temp control can be replaced with a dial type temp control, freezing up of fridge may indicate fin temp control has failed or possibly fallen off allowing for constant cooling to occur.
We have had both brands of RV fridges, they cool pretty much the same. What's paramount is that they are properly installed, many RV builders do a poor job not allowing for enough ventilation on the rear of the unit. Many turn to residential fridges primarily do to poor performance, anything to assist air movement for proper airflow behind fridge would indeed enhance cooling prowess of the unit.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
