Old-Biscuit
Oct 07, 2020Explorer III
BurbMan wrote:wopachop wrote:
He is saying when you are set to propane only there are no lights.
It only turns orange when propane fails to light.
Correct BUT...if you are set to "Auto" then the "auto" stays on regardless of whether you are running on elec or gas.
Only when the auto/gas button is in the "gas" position are no lights on.
The "check" light is separate from the "auto" light.
CORRECT!
OP...
As for that 'white thing'
That is the CLIP ...thermistor goes inside that clip with just the tip protruding from top of clip
Clip with thermistor goes on far right fin
Try Mid Fin Position 1st...wait 24 hrs and then check fridge temps
Adjust UP for Colder
Adjust DOWN for Warmer
W/O clip/thermistor attached to fin fridge thermostat doesn't get any temp feed back so it continues to call for cooling...hence a very cold fridge (food compartment freezing items)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
