dougrainer
Mar 03, 2014Nomad
Ojibwa53 wrote:
Thanks , the wire was dangling down on the rack not connected to the plastic clip, do you think that was the problem ?
Thermister NOT touching the fins would cause a TOO COLD condition. Repost when it does not work. Is your refer in a slide room? If so, the odds are, the rear cooling fan is NOT operating. The freezer should be below 10 degrees. IF it does NOT even get to 32 degrees(freezing), the Thermister is NOT your problem. Doug
