dougrainer
Mar 08, 2014Nomad
wa8yxm wrote:dougrainer wrote:Ojibwa53 wrote:
Fridge back to normal condition , wire had fallen off the clip at the cooling fin .
Thermister NOT connected to the fins will cause OVERCOOL, not undercool. Doug
Not necessarly, normally in a fridge the coldest part is the bottom, getting warmer as you approach the fins at the top, which by the way is why they are at the top.
The thermistor dangling down,,, Means it was in a colder part of the fridge.
Are you kidding me?????? Where do you come up with this nonsense??? The Thermister would be HANGING and not touching the solid surface. The Air in the refer will NOT be anywhere cold enough to cause the Thermister to sense anything but warmer and call on the refer to continue cooling. EVEN if it touched the plastic areas, those are way warmer than the FINS. The COLDEST part of the lower refer are the Aluminum FINS. The air circulating OVER those fins is how the cold is transmitted(heat removed) to the refer. The Fins are usually 10 degrees COLDER than the refer temp. So, if your items in the refer are at 38 degrees, then the FIN temp will be 28 degrees. The Thermister does NOT respond to actual refer temp but the COLDER section of the Fins. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
