raytronx
Jun 12, 2013Explorer
Ragingbull wrote:
I replaced my board several yrs ago with a Dinosaur P-711 due to a propane igniter issue. My son moved into it for about 6 months. As he's out now I'm going through the camper and found that the fridge won't start on AC. When you turn it on, the lights for DC and gas illuminate and it works on them. It won"t try to switch to AC. I checked all the fuses, verified the outlet is working, and checked for loose wiring. Any other things I should check into?
I just finished fixing mine,would not work on AC, gas OK, had a open heater element. Did a write up, photos and video of the job for reference. The fridge is a Dometic DM2652.
Ray
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
