Chris_Bryant
Jun 12, 2013Explorer II
A bad element will not keep it from trying to run on A.C. power, it just won't cool.
Did you actually measure the voltage across the fuse on the board? These fuses fail quite often by building up a bit of heat, and the element comes un-soldered from the end caps, so the fuse looks good, but doesn't conduct power.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
